Cisco Nexus 1100 port type cables
opnineopnine
Hi all,
I have to connect my Nexus 1100x cimc to my fex , the cable type will be Ethernet or it can be fiber cable? I also need to connect it to my fabric, this should also be Ethernet or it can be fiber ?
thanks.
Reza Sharifi
Ethernet runs over both copper and fiber. So, you can use either one.
Reza Sharifi
Hello Reza,
So just to be sure, I can connect user fiber cable to connect both of my ports?
thanks!!
Yes, that is correct.
I was trying to find the doc where the  Nexus 1100x show that I can use fiber and ethernet.
do you have any link to share?
thanks. again
