Cisco Nexus 2232 and HP c7000 Flex Fabric Switch
rahulja
Hello
As per my understanding, Cisco Nexus 2232 can only connect to HP c7000 Chassis if we are using a Pass Through Switch in the HP c7000. Cisco Nexus 2232 can only connect to End Hosts and not to a switch.
Is there a New Feature added in Nexus 2232, which enables it to connect to a Switch like HP Flex Fabric ?
thanks
regards
Rahul Jauhari
Jerry Ye
Not that I know of.
You can block BPDU coming from the Flex Fabric but this would cause STP loop if you don't do this carefully. This method is not recommended.
HTH,
jerry
