Cisco Nexus 3048 upgrade
Siva chinap
Level 5
Level 5
I intend to upgrade Nexus 3048 switches from 6.0(2)U6(4) to 9.3 (8). I'd like to know if straight upgrades are supported, or if I need to upgrade intermediate versions. How long will this upgrade take and required procedure, prerequistes?
Hi Siva,
An ISSU will not be possible in this situation. A disruptive NX-OS upgrade is your only option for this upgrade path.
Thank you!
-Christopher
6 Replies 6
balaji.bandi
read the release notes and upgrade :
Upgrade From NX-OS 6.x to NX-OS 9.3(x)
This section of the document describes how to perform a standard disruptive NX-OS software upgrade from a source release in the NX-OS 6.x major release to a target release in the NX-OS 9.3(x) minor release.
Note: An NX-OS software upgrade to a target release in the NX-OS 9.3(x) minor release from a source release in the NX-OS 6.x major release requires two mandatory intermediate upgrades. The first intermediate upgrade is to NX-OS 6.0(2)U6(10). The second intermediate upgrade is to NX-OS 7.0(3)I7(9). After the second intermediate upgrade to 7.0(3)I7(9), you may upgrade to the desired target release in the NX-OS 9.3(x) minor release.
An example standard disruptive NX-OS software upgrade is performed on a Cisco Nexus N3K-C3172PQ-10GE switch from a source release of 6.0(2)U5(1) to a target release of 9.3(5) with mandatory intermediate upgrades to 6.0(2)U6(10) and 7.0(3)I7(9).
https://www.cisco.com/c/en/us/support/docs/switches/nexus-3000-series-switches/216037-nexus-3000-and-3100-nx-os-software-upgra.html#anc31
BB
Hi Balaji,
Just as an FYI, this is not the correct document for the Nexus 3048. The N3K-C3048 is not listed under the Applicable Hardware section of this document.
The appropriate document for the Nexus 3048 specifically is here.
Thank you!
-Christopher
Siva chinap
Level 5
Level 5
@balaji.bandi
Will it be able to do an upgraded ISSU update; is it advised; and, if so, which technique is recommended (disruptive or non-disruptive)?
Hi Siva,
Thank you!
-Christopher
@Christopher Hart cheers for the correct document.
I would suggest to manual upgrade one at a time, make sure you do this maintenance window. this service interruption upgrade,.
Note: Cisco always advises upgrading in time to minimize these kinds of issues. -
BB
DMace
This is just my failure story...take heed.
The upgrade path for the Nexus 3048 is a circus.  I did all the research and felt I knew the correct path.  I was upgrading from n3000-uk9.6.0.2.U2.2 to n3000-uk9.6.0.2.U6.10.  I had the kickstart and the system images...both verified.
I started the upgrade using the install all command.  Everything verified SUCCESS, everything extracted SUCCESS.
My switch rebooted after reporting SUCCESS and now I have a brick.  I get no console output, the ports never come up....its just a brick.
Cisco should be embarrassed at this upgrade process and the inability to recover.  Unfortunately I purchased the switch used and there is no warranty (it was working perfectly before this).  This helps justify in my mind that I will not purchase enterprise Cisco equipment for my home lab in the future.
