02-07-2011 02:32 PM - edited 03-06-2019 03:24 PM
Is there an option to go with 3rd party direct cable to connect Cisco Nexus 5000 switch to HP Virtual Connect for 10gb connectivity. Both Cisco and HP have their proprietary direct cable, but wondering if there is a 3rd party cable to solve the issue. Going with separate 10gb Transeiver and connect them over multimode fiber is little expensive since each 10gb transceiver cost is around $3000.00 for both Cisco and HP.
Please advise
Solved! Go to Solution.
02-08-2011 03:11 AM
02-07-2011 02:36 PM
Abbas,
As far as I know, you cannot use any 3rd party cable.That will an unsupported configuration both by HP and Cisco. Typically customers didnot want to use the Cisco proprietry cables so we went ahead and certified/tested the HP direct attach cable with Nexus 5K and HP VC. You have to either use Cisco cable or HP certified cable to work this out. I am afarid there is no other option, unless you really want to try other vendor and play a bet to just run it anyways.
Cheers,
-amit singh
02-07-2011 03:01 PM
Amit,
Are you saying that Cisco Properitary Direct Cable 10gb will work with HP Virtual Connect. Do you know that the cost of this cabel?
02-07-2011 03:19 PM
Yes, we did certify some cables to run with HP VC, if i remember correctly. I will get you the details tomorrow. Sorry, I dont know the price for this cable.
Cheers,
-amit singh
02-07-2011 03:28 PM
Amit,
Thanks for your quick repsonses. Really appreciate it. I will wait for the details that you will send tomorrow and go from there.
if you prefer, you can send directly to abbask.ali@gmail.com
02-08-2011 03:11 AM
Abbas,
Just sent you the details.
Cheers,
-amit singh
