High Queue drop rate
jopetik09
Level 3
Level 3
I have a router 2801 with two physical interfaces and two virtual interfaces created on Fa0/0 interface.
#x
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/0.1          10.10.1.1       YES NVRAM  up                    up
FastEthernet0/0.500        192.168.97.1    YES NVRAM  up                    up
FastEthernet0/1            192.168.49.2    YES NVRAM  up                    up
Tunnel1                    unassigned      YES NVRAM  up                    down
Since 4 days I was getting HighQueueDropRate on Fa0/0 and there was no hight utilization at that times.
#sh int FastEthernet0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 001b.5336.4404 (bia 001b.5336.4404)
  Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d01h
  Input queue: 0/75/62734/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 508000 bits/sec, 546 packets/sec
  5 minute output rate 768000 bits/sec, 117 packets/sec
     25405539 packets input, 3452447687 bytes
     Received 84769 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     5662837 packets output, 603362266 bytes, 0 underruns
     0 lost carrier, 0 no carrier
As per Cisco doc I enabled Priority Queue on the Ethernet interface to use four priority queues with varying queue limits. But still the Input queue drop rate is increasing.
1#sh int FastEthernet0/0
     reliability 255/255, txload 1/255, rxload 2/255
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:34:41
  Input queue: 0/75/1789/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: priority-list 1
  Output queue (queue priority: size/max/drops):
     high: 0/20/0, medium: 0/40/0, normal: 0/60/0, low: 0/80/0
  5 minute input rate 1162000 bits/sec, 656 packets/sec
  5 minute output rate 502000 bits/sec, 109 packets/sec
     1182428 packets input, 177848335 bytes
     Received 2367 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     234817 packets output, 145452777 bytes, 0 underruns
Can someone please suggest me what needs to be done to stop the drop rate.
Thanks in advance.
Jopeti.
Mahesh Gohil
Level 11
Level 11
Hello Jopeti,
Can ou provide configuration of interface and an qos applied
Mahesh
Hi Mahesh,
below is the interface config.
#sh run int FastEthernet0/0
Building configuration...
Current configuration : 161 bytes
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
no ip address
ip flow egress
duplex auto
speed auto
priority-group 1
end
Jopeti.
