Cisco Nexus 5K sup-active usage
Aknab Aknab
Hi Guys,
Nexus debug
SW1# dir debug://sup-active/
20946944 May 24 03:12:52 2015 processmib_debug.log
Usage for debug://sup-active
20971520 bytes used
0 bytes free
20971520 bytes total
The content are all similar.
<Sat Mar 21 18:37:29 2015> create_process_info(374): couldn't get process info, ret 0x0, sts 0x100
<Sat Mar 21 18:37:30 2015> create_process_info(374): couldn't get process info, ret 0x0, sts 0x100
<Sat Mar 21 18:37:31 2015> create_process_info(374): couldn't get process info, ret 0x0, sts 0x100
<Sat Mar 21 18:37:32 2015> create_process_info(374): couldn't get process info, ret 0x0, sts 0x100
I tried to delete the file but it is coming back, is this related to CSCug19319?
4653 May 24 03:32:12 2015 processmib_debug.log
8192 bytes used
20963328 bytes free
Does it requires IOS upgrade?
How to avoid this. Thanks
7 Replies 7
It is the debug log file for SNMP.
Show run | include snmp
Show run | include mib
Find something related to snmp or mib and remove it by no command.
The command is "no debug snmp mib" on other routers and swiches, but I am not sure on nexus.
Masoud
Hi Masoud,
I only have this configuration in snmp.
snmp-server host 172.4.2.2 traps version 2c <omitted>
snmp-server enable traps callhome event-notify
snmp-server enable traps callhome smtp-send-fail
snmp-server enable traps cfs state-change-notif
snmp-server enable traps lldp lldpRemTablesChange
snmp-server enable traps cfs merge-failure
snmp-server enable traps aaa server-state-change
snmp-server enable traps upgrade UpgradeOpNotifyOnCompletion
snmp-server enable traps upgrade UpgradeJobStatusNotify
snmp-server enable traps feature-control FeatureOpStatusChange
snmp-server enable traps sysmgr cseFailSwCoreNotifyExtended
snmp-server enable traps config ccmCLIRunningConfigChanged
snmp-server enable traps snmp authentication
snmp-server enable traps link cisco-xcvr-mon-status-chg
snmp-server enable traps vtp notifs
snmp-server enable traps vtp vlancreate
snmp-server enable traps vtp vlandelete
snmp-server enable traps bridge newroot
snmp-server enable traps bridge topologychange
snmp-server enable traps stpx inconsistency
snmp-server enable traps stpx root-inconsistency
snmp-server enable traps stpx loop-inconsistency
snmp-server enable traps poe portonoff
snmp-server enable traps poe pwrusageon
snmp-server enable traps poe pwrusageoff
snmp-server enable traps poe police
snmp-server community <omitted> group network-operator
No result for mib.
set this command
Undebug all to deactivate all debug commands, then check to see the file gets larger or not.
Masoud
I have no running debug on my switch.
Also try this
logging persistent url flash
sh run | include logging
sh run | include flash
sh run | include url
Masoud
Ganesh Hariharan
Hello Aknab,
The Bug detail shown is for cisco Nexus 1000v switches.
Are you running any debug command on your switches.Becuase log files are created on dir:log file in Nexus switches.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/command/reference/fund/n5500-fund-cr/n5500-fund_cmds_d.html#pgfId-1307360
Hope it Helps..
-GI
Hi Ganesh,
I tried it but it does not help.
I dont have running debug from my nexus switch.
SW# show debug
Debug level is set to Minor(1)
default for new sessions logging level: 3
