Setting up a LAG with LACP between 3750-X and SG300-10
bgarcia
I am using a stacked pair of 3750-X switches as the core for a network, and there is one location where I need to hook up some devices where I would like to place a local SG300-10 and use a 2 port LAG between the SG300-10.   When I look at status of the LAG (Etherchannel) on the 3750-X it shows as being up.   When I look at the status on the SG-300 it appears to be up.   When I unplug and plug the ethernet cable I see the VLANs on the LAG go up and down from the SG300 log.
Log IndexLog TimeSeverityDescription
21474834532013-Oct-31 19:11:04Informational%AAA-I-CONNECT: New http connection for user cisco, source 192.168.56.112 destination 192.168.56.206 ACCEPTED
21474834542013-Oct-31 19:07:23Informational%AAA-I-DISCONNECT: http connection for user cisco, source 192.168.56.112 destination 192.168.56.206 TERMINATED
21474834552013-Oct-31 18:57:08Informational%LINK-I-Up:  Vlan 3
21474834562013-Oct-31 18:57:08Informational%LINK-I-Up:  Po1
21474834572013-Oct-31 18:57:08Informational%TRUNK-I-PORTADDED: Port gi9 added to Po1
21474834582013-Oct-31 18:57:05Informational%LINK-I-Up:  gi9
21474834592013-Oct-31 18:56:30Warning%STP-W-PORTSTATUS: gi1: STP status Forwarding
21474834602013-Oct-31 18:56:26Informational%LINK-I-Up:  Vlan 2
21474834612013-Oct-31 18:56:26Informational%LINK-I-Up:  gi1
21474834622013-Oct-31 18:54:53Warning%LINK-W-Down:  Vlan 3
21474834632013-Oct-31 18:54:53Warning%LINK-W-Down:  Vlan 2
21474834642013-Oct-31 18:54:53Warning%LINK-W-Down:  Po1
21474834652013-Oct-31 18:54:53Warning%LINK-W-Down:  gi9
21474834662013-Oct-31 18:54:53Warning%TRUNK-W-PORTREMOVED: Port gi9 removed from Po1
I have set a couple of ports on the SG-300 to be untagged on the the VLANS and I do not get IP addresses assigned via DHCP, I plug in something statically addressed with that VLAN, and I cannot reach it.   I also cannot reach the admin web pages for the switch via the trunked interface.  The same configuration on the 3750-X works with the Gigabit port on Catalyst Express 520 so I think the 3750-X is configured properly.
Config Info from the SG300
LAG Config Info
VLAN Config Info
Any thoughts on where I might have gone wrong would be greatly appreciated.
Thx
Bryan
Yordi Mahieu
I have a Stack of catalys 2960X with 31 sg300 series switches, with 15 diffrend LACP of 2 links.
in this LACP i have about 20 Vlans .
in the screen shot of the LAG i always use TRUNK as VLAN mode !
Make sure at both sides the "untaged" vlans is de same one .
SG300 do not support de cisco prop. protocol. so make sure u use LACP on the other side !
greetings.
