Cisco Nexus 7009 error message
Jozef Staruch
Hi All,
I have in logs following error message , could you please explain what is reason
%DEVICE_TEST-2-PWR_MGMT_BUS_FAIL: Module 1 has failed test SpineControlBus 20 times on device Power Mgmt Bus on slot 10 due to error Spine control test failed error number 0x00000002
thank you
Hi Jozef,
Can you please mark the question as answered so that it is not open anymore.
Please rate all helpful posts and close solved questions
Inayath
InayathUlla Sharieff
Hi Jozef,
The error message you are seeing is referring to the SpineControlBus Test.
The spine is another word for a Xbar/Fabric modules. In our case module is
failing this test for Xbar in slot 10.
This test checks the standby control  bus connectivity from the spine card
to the active Supervisor card. There are two control buses from each of the
Supervisor modules to every spine  card. Only one of them is used, while the
other is kept as a backup in case the  primary fails. This test is
auto-disabled after 20 consecutive failures, which is why the test shows as
err-disabled. Failure of this GOLD test is not considered catastrophic, but
it is an indication of 'reduced' high-availabilty for that Sup-Spinecard
pair.
Action plan:
Reseat the module
If happen to see msg again then replace the Sup.
An enhancement bug "CSCuc72466" has been filed already to avoid such failures in future releases.( Ref:https://supportforums.cisco.com/docs/DOC-30886)
Inayath
******Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Thank you for explanation..
Hi Jozef,
Inayath
