Cisco Nexus 7010 NX-OS 5.2 Netflow FPS Information
plantowski
Does anyone know how to get a summary of netflow statistics on NX-OS? On IOS you could do sh ip cache flow which would show what I need? Can't find a similar command on the Nexus Platform Thanks.
nkarpysh
Well,
From what I know you can try:
show flow-sampler
show ip cache verbose flow
show ip flow export template
Nik
HTH,
Niko
Unfortunately, these appear to be IOS commands. There was an easy way to get this information in the Catalyst switches but unfortunately this does not work in NX-OS which is the information I am looking for.
You can use "show flow sw-monitor cache" command to display information about NetFlow flow exporters and statistics.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
