Cisco NEXUS 9000 Wake On Lan (howto)
Pedro Santos
I have wake on lan working on a network with 2 segments, connected with a 2801 router configured to forward broadcasts (udp port 7) from wol-server to wol-client network.
WOL command from WOL Server Network
WolCmd.exe D4CEFC8F71E5 255.255.255.255 255.255.255.255 7
Wake On Lan signal sent to Mac Address D4CEFC8F71E5 via Broadcast Address 255.255.255.255 on port 7
WOL package being forwarded from one network to the other
RouterWOL#debug ip udp
Sep 22 14:04:06.439: UDP: rcvd src=10.10.2.34(1652), dst=255.255.255.255(7), length=110
Sep 22 14:04:06.439: UDP: forwarding packet 255.255.255.255(1652) to 10.10.103.255(7)
Sep 22 14:04:06.439: UDP: forwarded broadcast 7 from 10.10.2.34 to 255.255.255.255 on FastEthernet0/1
RouterWOL#
Router WOL configuration
RouterWOL#show  running-config
Building configuration...
interface FastEthernet0/0
 description WOL-ServerNetwork
 ip address 10.10.2.249 255.255.255.0
 ip access-group 122 in
 ip helper-address 10.10.103.255
 duplex auto
 speed auto
interface FastEthernet0/1
 description Wol-ClientNetwork
 ip address 10.10.100.1 255.255.252.0
 ip access-group 123 in
 ip directed-broadcast 110
 duplex auto
 speed auto
ip forward-protocol udp echo
ip access-list extended WolCmdACL
 permit udp any any eq echo log
access-list 110 permit udp host 10.10.2.34 any eq echo log
access-list 122 permit udp host 10.10.2.34 any eq echo log
access-list 122 permit udp any any eq ntp log
access-list 122 permit tcp any any eq 22 log
access-list 123 permit tcp any any eq 22 log
access-list 123 permit icmp any any echo
access-list 123 permit icmp any any echo-reply
On the PC I receive the WOL Magic Packet and the computer wakes on.
Here is a sample of the package received by the client PC
  Frame: Number = 180, Captured Frame Length = 144, MediaType = ETHERNET
- Ethernet: Etype = Internet IP (IPv4),DestinationAddress:[FF-FF-FF-FF-FF-FF],SourceAddress:[00-19-E7-91-DC-51]
  - DestinationAddress: *BROADCAST [FF-FF-FF-FF-FF-FF]
     Rsv: (111111..)
     UL:  (......1.) Locally Administered Address
     IG:  (.......1) Group address (multicast)
  - SourceAddress: Cisco Systems 91DC51 [00-19-E7-91-DC-51]
     Rsv: (000000..)
     UL:  (......0.) Universally Administered Address
     IG:  (.......0) Individual address (unicast)
    EthernetType: Internet IP (IPv4), 2048(0x800)
- Ipv4: Src = 10.10.2.34, Dest = 255.255.255.255, Next Protocol = UDP, Packet ID = 11561, Total IP Length = 130
  - Versions: IPv4, Internet Protocol; Header Length = 20
     Version:      (0100....) IPv4, Internet Protocol
     HeaderLength: (....0101) 20 bytes (0x5)
  - DifferentiatedServicesField: DSCP: 0, ECN: 0
     DSCP: (000000..) Differentiated services codepoint 0
     ECT:  (......0.) ECN-Capable Transport not set
     CE:   (.......0) ECN-CE not set
    TotalLength: 130 (0x82)
    Identification: 11561 (0x2D29)
  - FragmentFlags: 0 (0x0)
     Reserved: (0...............)
     DF:       (.0..............) Fragment if necessary
     MF:       (..0.............) This is the last fragment
     Offset:   (...0000000000000) 0
    TimeToLive: 127 (0x7F)
    NextProtocol: UDP, 17(0x11)
    Checksum: 24586 (0x600A)
    SourceAddress: 10.10.2.34
    DestinationAddress: 255.255.255.255
- Udp: SrcPort = 1699, DstPort = Echo(7), Length = 110
    SrcPort: 1699
    DstPort: Echo(7)
    TotalLength: 110 (0x6E)
    Checksum: 35915 (0x8C4B)
  - UDPPayload: SourcePort = 1699, DestinationPort = 7
     UDPPayloadData: Binary Large Object (102 Bytes)
…And everything is working fine…
Now I need to replace the RouterWOL (Cisco C2801) by a C9504 Cisco NEXUS, but unfortunately it seems that NXOS (ver 6.1(2)I3(2)) does not support some functions like;
Any Ideas on how I can transfer the UDP redirect/forward from the Router to the NEXUS?
Nuno
7 Replies 7
Hello...
Anyone knows if Release 7 allows for WOL configuration?
Thank you
Nuno
jcamposo
Hello Pedro,
In this case definitely based on my research regarding a case, I admit this feature is not available for Nexus 9k,  currently  Nexus 9k chassis does not support such functionality.
This said, please be advised that supportability need was already raised to development team and tracked under enhancement request CSCuu60491< https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu60491/?reffering_site=dumpcr>;;; (N9K:NX-OS-allow any udp broadcast with ip helper-address just like IOS). WoL will not work in "broadcast mode" because "ip forward protocol" is not supported. But you can work with ‘directly broadcast mode’. For WOL to work on Nexus in "directed broadcast mode", you need to meet following requirements: 1) Configure the WOL server to send packets to network broadcast address rather than all network broadcast address 2) Configure "ip directed broadcast" on the user vlans where the machines need to woken up.
Josue Campos
Data Center Routing and Switching Cisco TAC
Email: jcamposo@cisco.com
Am I missing something?
<sender of wol packet>
Wake On Lan signal sent to Mac Address 020040404f50
via Broadcast Address 172.22.2.255 on port 7
cisco Nexus9000 C9504
interface VlanServer<sender of wol packet>
no ip redirects
ip address 172.22.2.252/24
no ipv6 redirects
ip dhcp relay address 172.22.103.255
interface VlanUsers<receiver of wol packet>
no ip redirects
ip address 172.22.103.252/22
no ipv6 redirects
Thank you
Based on what I see you have applied the ip directed-broadcast command under the proper SVI, that should be good enough as per previous statement as a workaround.
Dear Josue Campos,
Thanks for your reaction
You mean the WOL server should send packets to the server VLAN's broadcast address , correct ?
Thanks and Regards
Sander
Kevin Martin
IP Helper command is 'ip dhcp relay address xx.xx.xx.xx' in NXOS.  I don't believe that the ip forward-protocol udp echo is needed in NXOS.
Kevin
***Please Mark and Rate helpful posts***
I'm having the exact same issue as others have posted about
Using WOLCMD.exe to send magic packet to workstations and servers to power them for maintenance.
Prior to network upgrades this worked perfectly for years. Now, we upgraded to nexus 9000 and this is broken. We're being told this is not possible in the 9000 series. Am I being told correctly? In 2020 a Cisco switch cannot support a WOL magic packet?
Someone has to know of a work around. I simply refuse to believe this hasn't been solved by someone somehow.
If you know how to get around this, please post the solution in specific instructions. I am not the strongest at this and need to know exactly what to do to resolve this ASAP.
Thanks much
Jimm "I can't send my magic packet" Panik
