Cisco Nexus 93180YC-FX 25Gb Problem
Samuel Berhanu
Last time I asked if the Cisco Nexus 93180YC-FX 25Gb port did not work
https://community.cisco.com/t5/switching/cisco-nexus-n9k-c93180yc-fx-does-not-active-25gb-nutanix-   node/m-p/4626372#M525352
But since the current firmware has been upgraded form NXOS.9.3.5 to NXOS.9.3.9 only maximum 8-port only function 25Gb the other are not why ?
Interface configuration file is here …..
               interface Ethernet1/1
                     description CB0_NX_OS-6_P1 <---> CBO_NTXCLDR1_N1_Eth1
                     switchport
                     switchport mode trunk
                     switchport trunk native vlan 602
                     switchport trunk allowed vlan 112,114,602-603
                     fec auto
                     no shutdown
balaji.bandi
what are that 8 port runing ok ?
can you post
show interface Ethernet1/1
BB
balaji.bandi
can you post
BB
CBO_NX_OS_06_DR_SW(config)# show int eth1/1
Ethernet1/1 is up
admin state is up, Dedicated Interface
Hardware: 100/1000/10000/25000 Ethernet, address: 38fd.f81c.aaab (bia 38fd.f81c.aaab)
Description: CB0_NX_OS_6_P1 <---> CBO_NTXCLDR1_N1_Eth1
MTU 1500 bytes, BW 25000000 Kbit , DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
full-duplex, 25 Gb/s, media type is 25G
Beacon is turned off
Auto-Negotiation is turned off FEC mode is Fc-fec
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is Fc-fec, oper fec state is Fc-fec
Last link flapped 00:04:35
12 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 96 bits/sec, 0 packets/sec
30 seconds output rate 3768 bits/sec, 5 packets/sec
input rate 96 bps, 0 pps; output rate 3.77 Kbps, 5 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 96 bits/sec, 0 packets/sec
300 seconds output rate 447336 bits/sec, 4 packets/sec
input rate 96 bps, 0 pps; output rate 447.34 Kbps, 4 pps
RX
     316610804 unicast packets 7393 multicast packets 31159 broadcast packets
     316651232 input packets 341196087076 bytes
     8065 jumbo packets 0 storm suppression bytes
     0 runts 55 giants 1821 CRC 0 no buffer
     1876 input error 0 short frame 0 overrun 0 underrun 0 ignored
     0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
     0 input with dribble 0 input discard
     0 Rx pause
TX
     277169279 unicast packets 177893 multicast packets 55652 broadcast packets
     277402912 output packets 300386024983 bytes
     7976 jumbo packets
     88 output error 0 collision 0 deferred 0 late collision
     0 lost carrier 0 no carrier 0 babble 0 output discard
     0 Tx pause
