Cisco Nexus 9K- SPAN Configuration
Dear Community,
We have deployed 2 Nexus9K switches as Core Switches. We want to configure SPAN port for 2 destination ports with same 2 nos. of source vlans. As per Nexuss limitation I can not add 2 destination ports in single Monitor session & can not add same vlans as source for multiple monitor session. What could be the alternate solution if I want to configure more than 2 SPAN ports for same no. of source vlans?
balaji.bandi
You have more sources, but you can only have 1 destination, that is limitation.
you can do more monitor configs
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/system_management/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_System_Management_Configuration_Guide/sm_14span.html#concept_03D78885AF7843E5948187D050BDA83D
If the sniffer has 2 IP address you can do 2 destination IP - is this works  for you ?
BB
Thanks BB,
We have 2 servers that requires 2 sniffer ports which are having same source vlans. Is it possible to achieve via any alternate solution?
Make clear :
you have same source but differerent destination right ?
do you have example config and what is the error you getting to understand ?
BB
