Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco nexus1000v install VEM fail[RunCommandError],But vsm is OK
hailin huang
Hi ,all
i install vsm is ok,on a single esxi5.0 host
my pc use vmware workstation 8,install a esxi5.0,windows2008.
my nexus version:
Nexus1000v.4.2.1.SV2.1.1
my esxi version:
VMware ESXi 5.0.0 build-469512
if i use  Nexus1000V-install_CNX,,install VEM,there is no host select ;
if i use CLI on vmware esxi,there is some Error.
the first command time :
~ # esxcli software vib install -d /vmfs/volumes/datastore1/test/VEM500-20121019150116-BG-release.zip
[RunCommandError]
Command '['/sbin/jumpstart', '--method=start', '--plugin=libloadvem-v150.so']' terminated due to signal 11
Please refer to the log file for more details.
the secend command time:
[InstallationError]
Error in running mv /tmp/img-stg/data/cisco-ve.v00 /tardisks/:
Return code: 1
Output: mv: cannot rename '/tmp/img-stg/data/cisco-ve.v00': No such file or directory
It is not safe to continue. Please reboot the host immediately to discard the unfinished update.
---------if i reboot ,Repeat the above
nexus1000v# show svs connections
connection vcenter:
    ip address: 192.168.190.1
    remote port: 80
    protocol: vmware-vim https
    certificate: default
    datacenter name: demohuang
    admin: n1kUser(user)
    max-ports: 8192
    DVS uuid: de 24 22 50 0a 1b e5 20-14 48 f6 88 35 39 72 92
    config status: Enabled
    operational status: Connected
    sync status: Complete
    version: VMware vCenter Server 5.0.0 build-434157
    vc-uuid: FF4A56F4-4D30-4266-967E-3507C5B18EC6
nexus1000v# show module
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          active *
Mod  Sw                  Hw
1    4.2(1)SV2(1.1)      0.0
Mod  MAC-Address(es)                         Serial-Num
1    00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8  NA
Mod  Server-IP        Server-UUID                           Server-Name
1    192.168.190.100  NA                                    NA
* this terminal session
Jason Shoemaker
Old issue, but posting my resolution to this issue in case anyone else hits it like I did and finds that there is next to nothing about this error message on the interwebs. The solution in my case was pretty simple: make sure that the N1KV VSM virtual machine (and all other virtual machines for that matter) are powered down on the host where you're attempting to manually install the VEM.  With any luck, your VEM install will succeed.
