cisco Nexus5596 interface status faulty
mgrabs
Hello Colleagues, i have running an cisco Nexus5596 Chassis at version 5.1(3)N2(1b) with N5K-C5596UP-SUP on customer side. now some Interface get status faulty:
XXX# show interface status module 1
th1/33         --                 faulty    1         full    10G     --
Eth1/34       --                 faulty    1         full    10G     --
Eth1/35       --                 faulty    1         full    10G     --
Eth1/36       --                 faulty    1         full    10G     --
Eth1/37       --                 faulty    1         full    10G     --
Eth1/38       --                 faulty    1         full    10G     --
Eth1/39       --                 faulty    1         full    10G     --
Eth1/40       --                 faulty    trunk     full    10G     --
find Bug Bug ID CSCul27686
Nexus 5548P: Interfaces may go down after upgrade & cannot be recovered
CSCul27686
match this BugID or is an Software or hardware issue?! please help me with advices!
Reza Sharifi
A software upgrade may remedy the issue.  I would start with that.
Hi Reza, many Thanks for your Reply! which Version is your recommendation?
in Customers Environment we have running 2 exactly identical cisco Nexus 5596 Chassis with N5K-C5596UP-SUP and Version 5.1(3)N2(1b) and same uptime since reload . only one of them get this behavior with faulty Interfaces. best regards Mike
Hi Mike,
It is hard to tell what feature sets you may need. Looking at Cisco's site, the recommended version for 5596UP is:
Cisco Nexus 5000 Series Switches 7.1(4)N1(1) for both systems and kick start
That said, I would read the release notes very carefully before loading any version to make sure you are aware of the features and caveats the version is providing.
