port forwarding to VPN LAN
JamesS4
Hi All,
I have a rather convoluted issue, which I think may have a very quick solution, but I do not have the expertise to figure this out.
We have our own local network (let's call it Network 1) connecting to two vendor networks.
One connects via direct point to point connection (Network 2).  They have given us a 2 address transport network.  We route to their end and they handle the traffic from there.  They route back to our Network 1 network ONLY.  If we want to use any other network, we have to NAT overload.
The other vendor LAN connects via VPN over Internet, which is NATed to our external public IP, by their requirement (Network 3).
Network 1: 172.30.50.xxx
Network 2: 10.9.21.xxx
Network 3: 172.40.100.xxx
Network 3 Transport: 172.40.200.xxx
So on our local router, for traffic from Network 1 to Network 3, we have a static route: ip route 10.9.21.0 255.255.255.0 [Internet next hop]
For traffic from Network 1 to Network 2, we have another static route: ip route 172.40.100.0 255.255.255.240 172.40.200.101.
Network 1 can talk to Network 2 and Network 3 with no issue.  Network 2 can talk to Network 1 directly.  Network 3 can talk to Network 1 via the public IP and port forwarding.
So the issue is, we want Network 2 and Network 3 to be able to talk to each other via Network 1 router.  I have tried to setup port forward rules going both ways.
This rule is intended for Network 3 to talk to Network 2:
ip nat inside source static tcp 172.40.100.3 22 [Network 1 public IP] 22 extendable
This rule is intended for Network 2 to talk to Network 3, by giving it a static Network 1 NAT:
ip nat inside source static tcp 10.9.21.3 22 172.30.50.60 22 extendable
But neither of these work.  Traceroute shows that they do reach the Network 1 router, but that's as far it goes.
Hopefully this is enough information (and not too much) to give an indication of where the issue lies.
Thanks in advance!
JamesS4
I think IP NAT ENABLE may be the solution I am looking for and not doing inside/outside designations.  I will come back with any results following further testing
JamesS4
