cisco Nexus7000 C7009 (9 Slot) Chassis ("Supervisor Module-2")
currently, I am using below-mentioned version
system image file is: bootflash:///n7000-s2-dk9.6.2.20.bin
Affected invulnerability issue needs to be upgraded which is the next version of IOS? which one  i need to upgrade? how could i find out the IOS upgrade path?
kindly do needful.
balaji.bandi
Suggest to look at the NXOS upgrade path :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_x/nx-os/upgrade/guide/b_Cisco_Nexus_7000_Series_NX-OS_Software_Upgrade_and_Downgrade_Guide_Release_7-x.html#concept_33E8A3F9941E4AF397CC59D3EAE198F3
The upgrade stable version only and can suggested, what module cards are in the chassis and what features are running.
If you not sure, suggest to contact cisco partner to help, since most of the Nexus Switches are installed in DC environment and critical service environment.
BB
