Cisco Packet Tracer question
Wilson Kwok
I'm setting InterVLAN routing on Packet Tracer, but it doesn't work on default route (I think), please download the file from attachment, you can see the network inculded two Vlan 10 and 20, those PC in those Vlan cann't ping to Router 192.168.0.1, I already setup default route on Layer 3 switch.
Please help.
Hardi Ahmed
Level 7
Level 7
Hello Wilson,
your configuration is correct you have been applied the correct configuration on the devices, but you missed to apply a static or dynamic routing on the router to the interconnection between the server that directly connected to the router and the other hosts in the network. on of the below commands can be apply on your router:
1- ip router 0.0.0.0 0.0.0.0 192.168.0.2 ...... this is static routing.
2- router eigrp 65010       .............. using dynamic routing protocol.
    net 192.168.0.0
    net 203.0.0.0
there is some different ways of configuration to apply the same interconnection.
should let me know if you need anything else.
best regards,
7 Replies 7
Wilson Kwok
Sorry, I forgot to post currently use the Cisco Packet Tracer version is 5.3.2.00.27, and that is installed on Windows 8 PC.
Can anyone help ?
Thanks !
OK now, I have setup rip on both L3switch and Router, the internal PC can ping to public server.
Dear Wilson Kwok,
          Hi,Wilson i checked your Packet tracer,default route is working fine. I think there was a problem in your PT version. Better try out with PT version 6. I checked your configuration in PTv6 and i found that there is no issue. You configured perfectly. I can ping the router from the host via L3 switch using default route.
          It may be helpful for you.
Thanks and regards,
Chanhuru.M
Thanks and regards, Chandhuru.M
Hardi Ahmed
Level 7
Level 7
Hello Wilson,
    net 192.168.0.0
    net 203.0.0.0
best regards,
Yeah, I have setup RIP both L3 and router that working find.
Herkennen in nieuwe situatie> bestaande.
Uitgewerkte PVE.
Waar moet de routering plaatsvinden, waar naartoe.
Welke VLAN gaan we gebruiken? Hoe wil je de VLAN’s geconfigureerd hebben. Welke naam?
Management, beheer? Black-hole, port security?
Wat gaan we met de server doen? Als domaincontroller?
Wat moet de server doen?
Hoe moet het netwerk worden voorzien van security?
Hoe gaan we om met de publieke subnetadressen?
Hoe gaan we de tijdelijke kantoorverbinding leggen? Wireless? Gigabit verbinding?
Hoeveel werkplekken komen er in het nieuwe netwerk?
Aansluitingen & Stroom, wie beheert dit?
Hoeveel Accespoint?
Hebben we een patchkast?
UPS geleverd worden?
Van huidige switch 2960 verhuizen naar nieuwe netwerk. Hoe ziet de verbinding er uit?. . multi layer switch?
Notities:
*Algemeen VLAN: word gebruikt voor overige apparaten, zoals printers.
*black hole vlan is voor de overige apparaten die geen vlan hebben, dient als port security.
Vermoede uitspreken. Geen netwerk bouwen als je niet weet wat je wil.
router op kantoor> dhcp device. Dhcp ook naar kantoor mls.
subnetten van ip adressering (pool) en daarnaast overload doen. 248 subnet. 2/3 ip adressen bruikbaar. Overload: Als alle drie vol zijn, dan word overload gebruikt.
nat pool implementeren op de router.
Multi Layer Switch. Hoe je een switchport> routed maakt.
Netwerk:
Trunking van core- naar switch. En van core naar switch routed interface poort maken.
Multi functional printer> aangesloten op switch 2960.
/24 gebruiken, je hoeft niet te subnetten.
Tijdelijke ruimte, tijdelijk netwerk.
WAN Verbinding blijft intact. NAT PAD Configuratie. In de inleiding.
Eisen en wensen
Invullen uit vragen die je gesteld hebt.
Inrichtingseisen:
Switch komt in een Afgesloten ruimte,
Wat de klant wil, wat gaat er veranderen in de nieuwe situatie
Beveiliging:
Anti-virus, hoogmogelijk beveiliging. Port security, GEBRUIKERS ALLEEN TOEGANG TOT EIGEN netweerk, fabrieksnetwerk en het internet.
Software:
Anti-virus pakket, Applicaties gebruiken. Remote control, welke browser, firefox. Boekhoudpakket, versie office.
Randvoorwaarden:
Alles waar je verantwoordelijk voor bent.
stroomvoorzening worden netjes door externe partij fgoed worden geinstalleerd.
Kosten voor investering conform eisen en wensen.,
UPS geleverd worden
Conclusies en aanbevelingen:
Nieuwe apparaatuur
Adviseren om AES te gebruiken. Office 2016 ipv 2013. Misschien andere software etc. suggesties geven hierin.
Routingprotocol: Default routs.
High Level Design
Gewenste situatie
van huidige switch 2960 verhuizen naar nieuwe netwerk. Hoe ziet de verbinding er uit?. . multi layer switch
Nieuwe situatie schetsen van maken. Knip en plakken van de oude omgeving.
Gebruik maken van SAAS.
Technische ontwerp
routed switchport. Etc. invullen.
Overnemen van High level design en van andere documentatie.
