06-11-2018 10:08 AM - edited 03-08-2019 03:20 PM
I have a Catalyst 3650 (IOS XE 3.6) with a module GLC-SX-MMD= (DOM capable). When I issue the command 'show interfaces gigabitethernet x/x/x transceiver detail', I can see the real-time operating parameters such as Optical Tx power, Optical Rx power, Laser bias current, Temparature and Transceiver supply voltage. For each parameters, I can see the minimum and maximum thresholds. It's possible costumize these thresholds of such parameters of DOM? When I insert a transceiver without DOM, the link go to state 'UP', but When I insert a Transceiver with DOM capable, the interface stay down. Could you please help me?
Solved! Go to Solution.
06-11-2018 03:00 PM
06-11-2018 03:00 PM
As far as I know, you can't modify those parameters.
06-12-2018 06:54 PM
