Cisco PIX Routing
atacan2006
Hello all,
I need your help. I cannot ping or access 2nd local subnet from PIX.
Structure:
PIX ---- Server 2003 ----Subnet1 + Subnet2
PIX
ip address outside pppoe setroute
ip address inside 192.168.5.254 255.255.255.0
Server 2003 IP Add1: 5.200
Server 2003 IP Add2: 10.200
From Client PCs I can access, ping internet addresses and other subnets. Working
From PIX I cannot only ping 5.200, cannot ping 10.200
What should I do?
Thanks in advance
PIX Config
access-list 101 permit ip 192.168.5.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 101 permit ip 192.168.10.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 102 permit ip 192.168.5.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 102 permit ip 192.168.10.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 103 permit icmp any any
icmp permit any outside
icmp permit any inside
ip local pool vpnpool 192.168.3.3-192.168.3.20
global (outside) 1 interface
nat (inside) 0 access-list 102
nat (inside) 1 192.168.5.0 255.255.255.0 0 0
nat (inside) 1 192.168.10.0 255.255.255.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group 103 in interface outside
Thanks in advance
Zati
22 Replies 22
acomiskey
Level 10
Level 10
Are all clients on 192.168.5.0 ?
route inside 192.168.10.0 255.255.255.0
Some clients are on 192.168.5.0 and some are 192.168.10.0.
All clients can reach all the possible networks (also internet) and can ping.
Only from PIX Firewall I cannot ping the network 192.168.10.0.
I have also tried the following:
that didn't work.
!!!I wrote by mistake that I cannot ping network 192.168.5.0 from PIX. That works...Sorry!!!
Thanks for your reply.
Now I'm confused....could you post a "show route" on the pix?
Here it is:
outside 0.0.0.0 0.0.0.0 (ISP_IP Address) 1 PPPOE static
inside 192.168.5.0 255.255.255.0 192.168.5.254 1 CONNECT static
inside 192.168.10.0 255.255.255.0 192.168.5.254 1 OTHER static
outside (ISP_IP Address) 255.255.255.255 (ISP_IP Address) 1 CONNECT static
Your route to the 192.168.10.0 network is pointing to the same gateway as your route to the 192.168.5.0 network.
This is the problem. 192.168.5.254 is the inside interface of your pix. So your routing table says to get to 192.168.10.0 go to the inside interface of the pix which is clearly wrong.
You have 2 subnets in your network
192.168.5.0
192.168.10.0
Do you have a router internally that routes between these subnets. if you do, then you need to do as Adam has suggested and point a route to the 192.168.10.0 network to go via your internal router eg.
say your internal router interface had an ip address of 192.168.5.253. On the pix
route inside 192.168.10.0 255.255.255.0 192.168.5.253
If you don't have an internal router then how are your running two separate subnets internally ?
Hope this makes sense
Jon
Thank u Jon, That makes sense.
I have a Window 2003 Server configured as RRAS.
W2K3 have 2 interfaces:
Interface1 :192.168.5.200/24
Interface2 :192.168.10.200/24
from the Clients I have no problem.
Host 192.168.10.40 can ping 192.168.5.254(router inside)
new sh route:
inside 192.168.10.0 255.255.255.0 192.168.5.200 1 OTHER static
Still cannot access or ping 192.168.10.0 network from PIX
(config)# ping 192.168.10.200
192.168.10.200 NO response received -- 1000ms
AqidosPix(config)# ping 192.168.5.200
192.168.5.200 response received -- 0ms
I'm not familiar with RRAS but do you have IP routing functionality turned on on the W2K3 server.
one thing you can try which might help narrow down where the issue is, on the pix
debug packet inside dst 192.168.10.200
debug packet inside src 192.168.10.200
This should show you how far the pings are getting ie. are they just leaving the pix or are you seeing packets coming back.
Can you try pinging a host beyond the 192.168.10.200 interface - ie any other host on the 192.168.10.x subnet.
Jon
I coud not ping a host too, but host can ping router interface.
I think the packets are just leaving
here is the ping info:
-------- PACKET ---------
-- IP --
192.168.5.254 ==> 192.168.10.200
ver = 0x4 hlen = 0x5 tos = 0x0 tlen = 0x3c
id = 0x5201 flags = 0x0 frag off=0x0
ttl = 0xff proto=0x1 chksum = 0xd7a8
-- ICMP --
type = 0x8 code = 0x0 checksum=0xf5d8
identifier = 0x1124 seq = 0x2
-- DATA --
00000010: 00 01 02 03 |
00000020: 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 | ..
00000030: 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f 64 | ..
..........d
--------- END OF PACKET ---------
--------- PACKET ---------
-- IP --
192.168.5.254 ==> 192.168.10.38
id = 0x5211 flags = 0x0 frag off=0x0
ttl = 0xff proto=0x1 chksum = 0xd83a
-- ICMP --
-- DATA --
..........d
192.168.10.38 NO response received -- 1000ms
Routing is obviously working as you can get to the internet from the 10 network. Are you sure these hosts are pingable, can you ping them from the same network?
Yup,
Host are pingable.
Example
HostA can ping HostB on 192.168.10.0 network
Server can ping Hosts on 192.168.10.0 network
Hosts can ping both interfaces of PIX
PIX can ping nur Hosts on 192.168.5.0 network
but cannot ping 192.168.10.0 network including 192.168.10.200(RRAS server)
Also Server can ping both networks.
Network
PIX(5.254)----(5.200)RRAS Server 2003(10.200)----(10.38)HostA----(10.40)HostB
HostC(5.10)
What is HostC connecting to in your diagram?
just for test purposes...
Okay this is getting very confusing :-).
Basically a ping from a client on 192.168.10.x will get a reply from the pix inside interface but the if the ping is initiated from the pix it doesn't work.
Do you have type of firewall on your 192.168.10.x clients that could be stopping this. unlikely as the pix can ping the 192.168.5.x addresses.
Only other thing i can think of at the moment is are there any settings in the RRAS configuration that would be stopping this.
What happens when you try and ping from a client in the 192.168.5.x network to a client in the 192.168.10.x network ?
Jon
It's very strange i know.
ping from a client in the 192.168.5.x network to a client in the 192.168.10.x network NOT WORKING!!!
ping from a client in the 192.168.10.x network to a client in the 192.168.5.x network WORKING (also can access resources ie:shared folders on 5.x client)
somehow routing or pinging works one-way
I'll stop all firewall, antivirus activities.
