Cisco PIX Routing
atacan2006
Hello all,
I need your help. I cannot ping or access 2nd local subnet from PIX.
Structure:
PIX ---- Server 2003 ----Subnet1 + Subnet2
PIX
ip address outside pppoe setroute
ip address inside 192.168.5.254 255.255.255.0
Server 2003 IP Add1: 5.200
Server 2003 IP Add2: 10.200
From Client PCs I can access, ping internet addresses and other subnets. Working
From PIX I cannot only ping 5.200, cannot ping 10.200
What should I do?
Thanks in advance
PIX Config
access-list 101 permit ip 192.168.5.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 101 permit ip 192.168.10.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 102 permit ip 192.168.5.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 102 permit ip 192.168.10.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 103 permit icmp any any
icmp permit any outside
icmp permit any inside
ip local pool vpnpool 192.168.3.3-192.168.3.20
global (outside) 1 interface
nat (inside) 0 access-list 102
nat (inside) 1 192.168.5.0 255.255.255.0 0 0
nat (inside) 1 192.168.10.0 255.255.255.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group 103 in interface outside
Thanks in advance
Zati
22 Replies 22
Yes, very strange. If the clients on both subnets have the same builds/settings i would concentrate on the setup of the RRAS server.
Jon
Just curious, what is default gateway for 5 network clients, inside pix or rras server?
Clients have 192.168.5.254 (router inside)
RRAS Server has no Default Gateway for 192.168.10.0 network.
Also for 192.168.5.0 network RRAS Server Default Gateway is 192.168.5.254
Why is the default gateway for the router, the router? Why not inside pix?
Sorry acomiskey I didn't understand your question.
for the RRAS Server
Interface1:
IP Address: 192.168.5.200/24
Default Gateway: 192.168.5.254 (IP Address of inside PIX)
Interface2:
IP Address: 192.168.10.200/24
Default Gateway: (No Default Gateway)
ok sorry, you referenced 5.254 being router ip address above, not pix.
Any chance you are using Pix/ASA 7.2x OS? There seems to be an issue with having multiple inside subnets with routes. The same-interface-traffic command is supposed to resolve the issue but for me it is not working correctly.
I am having this same issue right now.
Hi, I think I should upgrade PIX firmware. I have 6.4 and that ICMP routing works only higher OS like 7.x
I'll inform you if it works.
