12-17-2013 08:46 AM - edited 03-07-2019 05:07 PM
Dear folks,
I have a confusion in one of my deployments. My client ordered initially a UCS 220M3 server, which came along with a windows CD. It was supposed to be used as an LMS 4.1 server. Later on there were some variation and customer wants to have prime infrastructure over it. Now I am unable to understand how to do it. The server which came doesnt have any OS. It has one 600 GB hard drive. Can anyone guide me what should i do / or order additionally to work out through this. I am pasting the BoQ for this server which is the original one before variation, the task is to make it work with Prime Infrastructure. Along with this i am attaching some snaps of the physical server and CIMC console...just to clear out any doubts... i will be very thankful if you suggest me the correct way.
Part Number |
NMS |
LMS-4.1-100-K9 | Cisco Prime LMS 4.1 Base DVD - 100 device license | 1 |
R200-BUN-4 | UCS C200 M2 Rack Svr 1x E5506 1x4GB 1PS | 1 |
A01-X0113 | 2.13GHz Xeon E5506 80W CPU/4MB cache/DDR3 800MHz | 1 |
A02-M304GB2-L | 4GB DDR3-1333MHz RDIMM/PC3-10600/single rank/Low-Dual Volt | 2 |
R200-D1TC03 | Gen 2 1TB SAS 7.2K RPM 3.5in HDD/hot plug/C200 drive sled | 1 |
CAB-9K10A-UK | Power Cord 250VAC 10A BS1363 Plug (13 A fuse) UK | 2 |
R2X0-PSU2-650W-SB | 650W power supply w/added 5A Standby for UCS C200 or C210 | 1 |
MSWS-08R2-ENHV-RM | Windows Svr 2008 R2 EN (1-8CPU 25CAL) Media | 1 |
R2X0-ML002 | LSI 1064E (4-port SAS 3.0G RAID 0 1 1E ) Mezz Card | 1 |
N01-M304GB1 | 4GB DDR3-1333MHz RDIMM/PC3-10600/dual rank 1Gb DRAMs | 1 |
R2XX-G31032RAIL | Rail Kit for UCS C200 C210 Rack Servers (23.5 to 36) | 1 |
R200-BBLKD | HDD slot blanking panel for UCS C200 M1 Rack Servers | 3 |
R200-BHTS1 | CPU heat sink for UCS C200 Rack Server | 2 |
R200-PCIBLKF1 | PCIe Full Height blanking panel for UCS 200 M1 Rack Server | 2 |
R200-PCIBLKL1 | PCIe Low Profile blanking panel for UCS 200 M1 Rack Server | 1 |
R200-SASCBL-001 | Internal SAS Cable for a base UCS C200 Server | 1 |
CON-UCW5-R200BN4W | UC PLUS 8X5XNBDOS UCSC200M2RckSvr 1x E5506 1x4GB 1PS | 1 |
12-17-2013 02:21 PM
You have the necessary CPU, memory and hard drive specifications for an Express size installation (Reference).
To install Prime Infrastructure 2.0 you will need to first install VMware ESX/ESXi. This is documented in the same Getting Started Guide I linked to above at this link.
Once you get that far along, just follow the setup wizard and installation is pretty simple.
FYI you will get better attention to Prime questions over in the Network Management forum.
12-18-2013 07:54 AM
