Cisco Products
ibegbu.david1
Good day everyone.
Please, can you recommend any cisco switch and router that best fit the below descriptions.
1. Cisco Switch
  • Ethernet Services
  • L2VPN
  • Minimum 24 ports of 10G/1G Interfaces (SFP to determine whether interface is 10G or 1G and to also support 1G using RJ45)
  • Support of Port monitoring, spanning, etc.
  • Support Basic layer 3 functionalities
  • Dual power
  • Carrier Grade
  • Ethernet operations, administration, and maintenance (EOAM)
2. Cisco Router
  • Ethernet Services
  • L2VPN
  • IPv4, IPv6, and L3VPN
  • Layer 2 and Layer 3 multicast
  • 10x1GigE (minimum.)
  • Support BGP (VPNv4, IPv4), OSPF etc.
  • IP over dense wavelength-division multiplexing (IPoDWDM)
  • 4x10GigE (minimum.)
  • Ethernet operations, administration, and maintenance (EOAM) and MPLS OAM
  • Layer 2 and Layer 3 access control lists (ACLs)
  • Hierarchical quality of service (HQoS)
  • MPLS traffic engineering fast reroute (MPLS TE-FRR)
  • Multichassis link aggregation (MC-LAG)
  • Dual power
  • Carrier Grade
Thanks.
7 Replies 7
Leo Laohoo
For switch, look at WS-C3850-24XS-E.
Information required for Router is not sufficient: What is the total bandwidth the router is meant to process?
Thanks for the reply.
1. The minimum bandwidth the router may be processing is around 500Mbps
Also, what i meant in my initial post is
1. It should have a minimum 10 nos of 1GigEthernet ports (SFPs). And
2. A minimum of 4nos of 10GigEthernet ports (SFPs).
Awaiting your kind reply.
The router is the ASR 1006X.  You'll need to pick and purchase the RPESP and SIP.
For the 10-port SFP, the part number is SPA-10X1GE-V2 and you'll need one unit.
For SFP+, you'll need four SPA-1X10GE-L-V2.
Please help confirm if all the below can fit into the router before purchase.
ASR1006-X Cisco ASR1006-X Chassis
CON-SNT-ASR1006X SMARTNET 8X5XNBD Cisco ASR1006-X Chassis
ASR1K-OTHER ASR1K-other applications for Enterprise or SP- Tracking only
ASR1000X-FAN Cisco ASR1000-X Fan Module
ASR1000-ESP40 Cisco ASR1000 Embedded Services Processor, 40G
CON-SNT-ASR1000E SNTC-8X5XNBD Cisco ASR1000 Embedded Services Processo
ASR1000-SIP-BLANK Blank Cover ASR1000 SIP
ASR1000-RP-BLANK Blank Cover for ASR1000 RP
ASR1KX-PWR-BLANK Blank Cover for ASR1000 X Chassis Power Supply
ASR1000-ESP-BLANK Blank Cover for ASR1000 ESP
ASR1000-RP3 Cisco ASR1000 Route Processor 3
CON-SNT-ASR100RA SNTC-8X5XNBD Cisco ASR1000 Route
SASR1KRPUNLIK9-166 Cisco ASR 1000 RP2/RP3 UNIVERSAL W/O LI
M-ASR1K-RP3-8GB Cisco ASR1000 RP3 8GB
SLASR1-IPB Cisco ASR 1000 IP BASE License
CON-SNT-SLASR1IK SNTC-8X5XNBD Cisco ASR 1000 IP BASE License
M-ASR1K-SSD-100GB Cisco ASR1000 RP3 100GB SSD
ASR1KX-AC-1100W-D Cisco ASR1000-X 1100W AC Default Power Supply
CAB-ACU AC Power Cord (UK), C13, BS 1363, 2.5m
SPA-10X1GE-V2= Cisco 10-Port Gigabit Ethernet Shared Port Adapter
CON-SNT-10X1GEV2 SNTC-8X5XNBD 10-Pt Gigabit Enet Shared Pt Adptr
ASR1000-SPA SPA for ASR1000; No Physical Part; For Tracking Only
SPA-1X10GE-L-V2= Cisco 1-Port 10GE LAN-PHY Shared Port Adapter
CON-SNT-1X10GEV2 SNTC-8X5XNBD 1-Pt 10GE LAN-PHY Shared PT Adptr
I could be wrong but where's your SIP?
I haven't ordered one of these for a long time. Can you forward the list to your local Cisco R&S SE and get them to review it?
Hello.
Thanks for your responses, it has really helped me alot. I really appreciate.
Please, can i ask some questions:
1. I have read the datasheets for the SIP, RP and the ESP. What are their functions in the router and are their functions distinct from each other?
2. While configuring on the cisco website, i dont see any slot for the SIP. Can you help me with a part number that can work well for the router.
NB: MY local Cisco R&S has not been helpful.
Awaiting your kind response.
Raise a TAC Case.  The value of the equipment you're going to get is very substantial.  I don't want to make a mistake of getting you to buy something you don't need.
SIP stands for SPA Interface Port.  This is a wide line card with the SPAs slide in.
RP stands for Route Processor.  This is responsible for the routing and throughput.  The higher the number the higher the througput.
