i need help setting up dhcp on other routers
dolanduck.
i need help setting up dhcp on other router i turned on the interfaces and i got to to work on vlan 50 but i don't know what else is wrong. here is my packet tracer. i need help just stuck on this. and here what i made.  i cant put packet tracer IMG_20171119_195233.jpg
Julio E. Moisa
Imagine your LAN is on R1 and the DHCP is R3 so  first you must have connectivity between these routers, R1 must know how to reach R3 and it can be done through routing protocols or static routes.
R1
interface G0/1
ip address 172.16.1.1 255.255.255.0
ip dhcp helper-address 10.1.1.6  <--- R3 interface
router eigrp 100
no au
net 0.0.0.0
R2
router eigrp 100
no au
net 0.0.0.0
R3
ip dhcp pool LAN-R1
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
dns 8.8.8.8
router eigrp 100
no au
net 0.0.0.0
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
well i was using OSPF to communicate with them
see what i was doing was putting ospf on all 3 routers and on the router 3 lan i got dhcp to work. but on the other routers i can not.
Yes OSPF is good, verify  the dhcp parameters, the default-route is basically the gateway of each LAN. Could you please share your config?
