Cisco QOS with 4500
UniWAQ
I have to configured QOS on 4500 , I am using Etherchannel with two physical (10G ) interfaces. I have to confirm that I need to configure
Service-Policy output voip on Etherchannel interface also or not . Secondly I need to configure in output or input direction. please guide me.
class-map match-all voip
match dscp ef
policy-map voip
class voip
bandwidth percent 10
interface fast 0/0
service-policy output voip
interface fast 0/1
inter port-cha 9
Carlos Villagran
Hi!
With this you are only reserving 10% of your bandwidth configured with the bandwidth command in the interface. According to the following link, it seems the best choice is to configure it only in the physical interfaces and avoid doing it in the portchannel.
That bandwidth reservation is usually configured as output to reserve at least 10% when the queue gets congested.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/01xo/configuration/guide/config/qos.html#wp1608291
Hope it helps, best regards!
JC
