Cisco Router 4200 series setup, dhcp not going through HELP
mailabiny
I am configuring a Cisco router, 4200 series, and the router is not giving out DHCP.
I have set the router to take DHCP from the ISP router. Config below. Please help.
Interface gigabitethernet 0/0
Ip address dhcp
Ip nat outside
No shutdown
Interface gigabitethernet 0/1
ip address 30.30.30.1 255.255.240.0
Ip nat inside
No shutdown
Ip dhcp pool mainusers
Network 30.30.0.0 255.255.240.0
default-router 30.30.30.1
Dns-server 8.8.8.8 4.2.2.2
Ip route 0.0.0.0 0.0.0.0 192.168.1.1
Ip access-list standard 1
Permit any
Ip nat inside source list 1 interface gigabitethernet 0/0 overload
2 Accepted Solutions
The network and it mask not match your interface IP 30.30.30.1 255.255.240.0
MHM
@mailabiny hi, correct your DHCP pool network as below
Network 30.30.30.0 255.255.240.0
Good luck
KB
MHM
Good luck
KB
mailabiny
Thanks, for the help I have sorted out my dhcp now, but my internet is not going through. I changed my ip route 0.0.0.0 0.0.0.0 192.168.1.1 to ip route 0.0.0.0 0.0.0.0 dhcp since my WAN is dhcp, but still internet can't go through. What could be the problem? Thanks
