Cisco Router and Supernets
Kurt Warner
I have ten location that are all connected via a vlan 922. We have an eigrp Network.  Each location is there own class C subnet. The one i use in the example is 10.9.x.x 255.255.255.0 .
I would like to add a supernet 10.9.64.0-10.9.79.255  i tried this
interface Vlan64
 ip address 10.9.64.1 255.255.240.0
 ip helper-address 10.1.1.11
 ip pim sparse-mode
but it didnt work , do i need to add a route ?  not sure any help would rock ............the rest of the config is below?
interface Vlan1
 ip address 10.9.1.254 255.255.255.0
 ip directed-broadcast
 ip accounting output-packets
 ip pim sparse-mode
interface Vlan2
 ip address 10.9.2.254 255.255.255.0
 ip access-group 150 in
 ip helper-address 10.9.1.254
interface Vlan3
 ip address 10.9.3.254 255.255.255.0
interface Vlan5
 ip address 10.9.5.254 255.255.255.0
 ip access-group 180 in
 ip access-group 180 out
 ip helper-address 10.1.1.35
 ip pim sparse-mode
interface Vlan10
 ip address 10.9.10.254 255.255.255.0
 ip pim sparse-mode
interface Vlan192
 no ip address
interface Vlan922
 ip address 192.168.27.9 255.255.255.0
 no ip redirects
 ip pim sparse-mode
router eigrp 145
 network 10.0.0.0
 network 192.168.27.0
 no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.27.1
no ip http server
ip pim rp-address 10.255.1.1
Can you explain what you mean when you say it is not working?
Can you also post the output from "show vlan" and "show ip interface brief"?
You are aware that a VLAN SVI will not come up until that VLAN is active on interface or a trunk?
JEFF SPRADLING
Have you tried to "activate" the vlan?
conf t
vlan 64
I did  go in and name the Vlan and when i do a "show vlan" it shows vlan 64 active.  I can not however ping the gateway?
ok  once i added it to a port i was able to ping the gateway. might be the correct answer give me a few to test
