Cisco RV042 DUAL WAN (Not ISP)
kiran
I have two RV042 Dual WAN router. The current IP Address range is 192.168.100.1 - 192.168.103.254 / 22. We have extended LAN, 500 IP's in one premises in another 500 in another premises, but all are in the same subnet. Both premises are connected through OFC and RF (WiFi) as redundent link.
If OFC is down we manually switch over to RF and there exists downtime. We want to make use of both the links parallelly with load balancing and fault tolerance.
Will etherchannel feature work in RV042, or any other solution.
Request your kind guidance to proceed further.
Pawan Sharma
RV042 has features like Smart Link Backup and Load Balance and they are pretty easy to configure. Let me know if you need to get this done. Just raise a Cisco technical support request here and would get it done for you.
Pawan Sharma
https://itgears.io
Thanks for your reply.
I will contact support and then get back for any issue.
