Cisco RV042
AustinMas
Hello experts ,
Somebody please tell me if Cisco RV042 is a good enough router to support around 100 users or i need to buy a higher model or something .  I want to configure two internet connections onto it .
Also please tell me if the two internet lines can both be used simultaneously in a load balancing manner .
Can this be achieved by giving equal distances in the static route ? Also can policy based routing be used to direct traffic based on destination ports to different WAN ports ?
Haris P
Level 4
Level 4
I think RV082 is not enough for 100 users , May be you can go for Cisco 1941 or 2900 series routers
If you need to load balance two ISP links ,the best way will be to do IOS NAT load balancing as described below
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
