DHCP binding
iosolutions1
Community Member
I did this config :
ip dhcp pool Reserved_1
   host 192.168.10.170 255.255.255.0
   client-identifier 001f.3c4f.2d21
   default-router 192.168.10.1
But still after release&renew the IP on this PC it didnt get 192.168.10.170
I've tried to clear arp and dhcp binding and also reloaded the router. it doesnt bind my MAC.
Thanx,
      Arik
this is not a valid client-identifier but it is the mac address of interface so 2 choices here: whether keeping this address but then chqnge the command client-identifier by hardware-address or leave the command but prepend 01 to the mac address which will give
client-identifier 0100.1f3c.4f2d.21
Regards.
Alain.
10 Replies 10
skarthic
i)Does the entry show up as "manual" in "Show ip dhcp mapping" output
ii)How are you connected to the DHCP server.Is there a L3 device between them?
iii) Are you getting any IP at all ? Are you getting the same IP that the PC had earlier before configuring the static map?
Regards.
Alain.
You got that right..01 should be prepended for ethernet media as explained in the doc.
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfdhcp.html#wp1001108
Thanx. I'll check it again with the hardware-address option.
Arik
OK I switch it to hardware-address but again when I release renew my IP - nothing..
Thnx,
     Arik
Then use client-identifier but prepending your mac with 01
Regards.
Alain.
Did you try checking what is the client identifier info receievd in the DHCP discover packet.
You can check this using "debug ip dhcp server packet" command. If you could post this output we can find what is the client identifier info
sent by the PC.
Regards.
Alain, Karthic,
Thanx for your help, I changed it to the client-identifier 0100.1f3c.4f2d.21 and its working now.
maybe I can ask you one more thing:
I want to block one PC on my network. I tried doing so with mac binding and blocking the IP, but I notice that there is no problem to put other IP manualy and pass this block.
How can I block mac address ?
I know it can be done on switches but this commands dont apply on routers.
Thnx again,
Arik
You can do this with MQC:
class-map BAD_MAC
match source-address xxxx.xxxx.xxxx
policy-map BLOCK_BAD_MAC
class  BAD_MAC
drop
interface f0/0
service-policy input BLOCK_BAD_MAC
Regards.
Alain.
Alain, Thanx,
Great, its working fine.
