Cisco SDM problem
Faisal.Saoud
Level 5
Level 5
I have a Cisco 2821 router. And I want to manage the router with SDM software. II have already installed the software and when i launched the application, 2 windows appear and the configuration page does not open. Can you please help me out.
6 Replies 6
Mark Malone
Hi what way are you accessing SDM is it through HTTP or HTTPS , have you used the latest SDM software for that model ?
Your screenshot shows like its being accessed through c drive
2800 SDM
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/software/configuration/guide/2800swgd/2800over.html#wp52692
Hi Mark,
Thanks for responding.
I am accessing SDM with HTTP or HTTPs , Version of SDM =2.5
what is version of Java which SDM work to login the router GUI
did you try a different browser like firefox or chrome see if its the same issue
I presume your not going through a firewall either just standard access on the lan just in case theres a port blocked
http://www.cisco.com/c/en/us/td/docs/routers/access/cisco_router_and_security_device_manager/software/release/notes/SDMr25.html
Cisco SDM requires Sun Java Runtime Environment (JRE). The following versions are supported:
•JRE 1.5_09
•JRE1.4.2_08
•JRE 1.5.0_06
•JRE 1.5.0_07
•JRE 1.6.0_02
•JRE 1.6.0_03
Although the Cisco SDM application requires JRE to run, the Cisco SDM Express application included with Cisco SDM can run under the native Java Virtual Machine in the supported browsers, and also JRE.
Hi Mark,
The problem have solved now , i have uninstall any java program and disable popup blocker and try to login with SDM and done 🙂
ah very good , not unusual for java to be the issue when guis are involved  🙂
Hey mate,
Could you please give a detail answer ? I am now have  the same problem. And i suppose its Java fault .
Thanks.
