Cisco SF350 vlans management
flvctin
Hi guys. I have this configuration, as shown in the image below:
 I want to connect two cisco routers through two cisco sf350 switches using vlans. Previously, these routers were connected through an utp cable.
Fa0/1 interface on both switches is set as
switchport mode acces
switchport acces vlan 10
and Gi1 interface
switchport mode trunk
switchport allowed vlan add 10
but this dont work. I am confused by tagged and untagged switchport modes, switchport general, switchport customer.
 I was advised to use Q-in-Q to transport that vlan 3 with my vlan 10 acces ports, but this switch uses a different software and I dont know how to configure that. Could you help me? Thanks.
balaji.bandi
Not sure what is the Goal here? and you have not shared the configuration of the router?
if you looking only Q-in-Q config below for reference :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350-series-managed-switches/smb5827-configure-vlan-interface-settings-on-a-sx350-sg350x-or-sx550.html
BB
Hi. My goal is to have connection(ping) from one router to the other one. I dont have acces on routers config. I only know ports, ip and that there is a vlan 3 between them.
