Cisco SFP compatibility
Syed Farhan Ali
Level 4
Level 4
Dear Members,
Recently EoL for GLC-T has been announced and its replacement is GLC-TE.
A customer has purchased WS-C2960X-48FPD-L Switch and we have given them the new transceivers GLC-TE.
As per the GE Transceiver support compatibility matrix (on the following link), it shows that mentioned above switch supports both GLC-T and GLC-TE.
Cisco GE Compatibility Matrix
  • Customer needs to know if they connect GLC-T with GLC-TE (Copper Uplink), will it work?
  • Customer needs to know if they connect GLC-T with GLC-TE (Copper Uplink on CAT 6 Cable), will it work?
Can anyone please respond to these queries?
Farhan.
blue phoenix
Are you asking if this particular switch WS-C2960X-48FPD-L with a GLC-TE sfp will work if connected to another switch with a GLC-T sfp module?
In my honest opinion, I think it would work since GLC-T is only end of life and would be replaced by GLC-TE.  Usually when Cisco replaces it's SFP, is to add support on new technology while still supporting the old.
Can you not test the 2 SFP's on 2 switches not in prod?  (spare switches perhaps?)
Let me know if it works or not!
Cheers,
Mark Malone
Both are a 1000base-T so there is no reason they should not be fully backward compatible , same standard
