07-06-2015 11:08 PM - edited 03-08-2019 12:51 AM
Hi Team ,
We have 5 nos of cisco SG300-24P switch and we are unable to configure below senirao
Kindly help us to configure
Area | Section | Subnet Add | Networ Address | Subnet Mask | Wildcard | Broadcast Address | Host | IP Range | Switch |
RACK 1 | SEG | 192.168.0.0 | 192.168.0.0/27 | 255.255.255.224 | 0.0.0.31 | 192.168.0.31 | 30 | 192.168.0.1 - 30 | Switch 1 |
RACK 1 | SEG | 192.168.0.32 | 192.168.0.32/27 | 255.255.255.224 | 0.0.0.31 | 192.168.0.63 | 30 | 192.168.0.33 - 62 | Switch 1 |
RACK 2 | SEG | 192.168.0.64 | 192.168.0.64/27 | 255.255.255.224 | 0.0.0.31 | 192.168.0.95 | 30 | 192.168.0.65 - 94 | switch 2 |
RACK 3 | SEG | 192.168.0.96 | 192.168.0.96/27 | 255.255.255.224 | 0.0.0.31 | 192.168.0.127 | 30 | 192.168.0.95 -126 | Switch 3 |
RACK 4 | SEG | 192.168.0.128 | 192.168.0.128/27 | 255.255.255.224 | 0.0.0.31 | 192.168.0.159 | 30 | 192.168.0.129 - 158 | Switch 4 |
RACK 5 | SEG | 192.168.0.160 | 192.168.0.160/24 | 255.255.255.224 | 0.0.0.31 | 192.168.0.191 | 30 | 192.168.0.161 - 190 | Switch 5 |
Suresh Kumar K
07-07-2015 12:17 AM
this will show you everything you need to know to get them up and running
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
07-07-2015 02:31 AM
Hi Mark,
For the above scenario how to do the configiguration can you pls guide me
i have created VLAN 10 in each switch and configured DCHP on the same VLAN, but i am not able to ping to the server which is in switch 1 (192.168.0.1 - 192.168.0.30)
regards
Suresh Kumar K
07-07-2015 03:12 AM
Is this just a layer 2 setup , have you set your default-gateway on each switch and configured a trunk port for them to connect to each other , you have created dhcp on the vlan, are the end devices getting an ip address from the range
07-07-2015 03:34 AM
yes I have given default-gateway to each VLAN and enabled the trunk port and as per the Switch DHCP server ip address are getting to the end devices but we are not able to communicate from one switch to another switch
07-07-2015 04:39 AM
looking at those subnets there all different whats doing the routing between them , is vlan 10 your management vlan then each switch should have an ip in the same range so they reach each other , if you want each subnet to talk to each other and there different vlans you need one of your devices to do intervlan routing so one of them has to be set as layer 3
07-07-2015 05:36 AM
can we do intervlan routing on SG300 Series Switch
07-07-2015 05:55 AM
yes they can you just need to set the device to be layer 3 mode they come out of the box as layer 2 , then turn on routing --ip routing and configure the layer 3 vlans on the switch , you should be able to route between the vlan interfaces then so devices on different subnets can talk together
https://supportforums.cisco.com/discussion/11520346/cisco-sg300-10-how-set-inter-vlan-routing
07-07-2015 02:37 AM
Hi Mark,
Can we do the below scenario in SG 300 Series Switch
Suresh
