Cisco SG250-50 fast blinking after firmware upgrade
joelgsus
Hello all,
I just got this switch and I was setting it up I figured I just update it to the latest firmware version 2.5.8.12 for it.
I went to the menu and I uploaded the new firmware and click on install and it took a very very long time on the loading screens almost an hour. I new something was wrong so restarted the switch but it’s not doing anything else but blink continuously and is not responding to any ports I connect to.
I tried resetting it but it comes to same blinking status. Did I just bricked it? There is no console port only One USB port and the rest are just ports. Please help me. Not finding much in google.
thanks
is in advance.
that's happening when system looking for DHCP to get a IP address. you can use tftpd or another DHCP server to connect with switch and it will release new IP to switch. then use that IP to access the switch.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf_sg250/quick_start/guide/en_US/78-100762-01A0.pdf
rate this and mark as answer if this resolved your concern
Good luck
KB
Good luck
KB
joelgsus
Thanks @Kasun Bandara for your comment. Switched already started working after staring at it and rebooting quite a few times. Now I know that I can use another dhcp server as a work around if it happens again. Thanks.
