Cisco SG300 28 and RV345 VLAN Setting
saids3
Hell0 All –
I need your help in this configuration please.
I have setup below setting in both Firewall and Cisco Switch SG300 -
  1. Cisco Firewall RV345 set with two VLANS –
    1. VLAN1 (Default) – 192.168.1.1 – Untagged – Port 1 – 255.255.255.0 – DHCP enabled.
    2. VLAN2 10.200.20.1 – Tagged – Port 1 – 255.255.255.0 – DHCP enabled.
  2. Cisco (L3) Switch SG300 28 POE+
    1. VLAN1 (Default) – 192.168.1.1 – Extended – All The Ports except Port GE5 –
    2. VLAN2 (NEW VLAN Created) – 10.200.20.0 – Untagged – Access Mode – Assigned Port GE5 –
  • Usually the routing in Cisco Switch SG300 is happening automatically once I connected any devices –
  • My issue is I’m not able to get internet connection from GE5 if I connect a PC or WiFi Access Point? I can Ping 10.200.20.1 -
  • I'm not sure if I need Static Routing in Firewall RV345? and How can be done or what would be the Destination IP and Next Hop and also the Interface?
I would appreciated the support in this case???
Thanks –
from what you are saying it looks like you have the same IP addresses and IP address space on both devices ? One (preferably the SG300) needs to be in layer 2 mode for your setup to work, and the link to the RV345 needs to be a trunk link...
6 Replies 6
Thank you for the reply
The link between switch and RV345 in "Trunk Mode" I have changed and still not getting IP or internet connect -
I dont know about the L3/ or L2 - if going to make any different - because mostly recommended to be in L3
make the SG300 a layer 2 device and check if the machines connnected to GigabitEthernet5 are getting IP addresses...
Thank you for the reply -
I returned the switch to L2, unfortunately didn't work!
I'm still stuck and unable to have the second VLAN is working - If anyone would illustrate the right way to do this from CISCO? please.
Here is some information about if the switch should be in L3 or L2.
https://community.spiceworks.com/how_to/72048-enable-inter-vlan-routing-with-cisco-sg-series-smb-layer-3-switches
Issue Resolved - Appreciated Team.
How did you fix it ? Were you able to keep the switch in L3 and NAT the VLAN internet traffic on the RV345 ?
I am looking to buy SG350 and still searching for an affordable router to make me able to get internet access for all the VLANs I want.
