Cisco smart account configuration on Catalyst 9300
hk24596
Dear All,
We're planning add our 9300 into cisco smart account . I've also referred  below cisco link - how to setup cisco smart account and add catalyst device into my account. Apart from creating new cisco smart portal account and activating , I've bit confused which type of device configuration suits my requirement. i will be so glad if someone could help.
Traffic Flow:
Catalyst 9300 (10.0.0.10)------>Proxy(192.168.1.1)---------->CSSM(tools.cisco.com)
Company email: abc@xyz.com
Reference link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/configuration_guide/sys_mgmt/b_169_sys_mgmt_9300_cg/configuring_smart_licensing.html#task_rr5_4rq_w3b
Attached the topology Sample to this thread.
Thanks much in advance !
Leo Laohoo
Cisco Smart License (CSL) starts from 16.9.1 until 17.3.1.
Keep it simple.  Avoid using IOS-XE versions with CSL.
New Deployment Method for Smart Licensing
Thank you @Leo Laohoo  for your reply.
