etherchannel support between Active-passive FTD-VSS switch
yong khang NG
Level 7
Level 7
Hi All
Would like to check out is it feasible to do both end back-to-back etherchannel between these device
a pair of cisco FTD in active-passive HA setup connecting catalyst switch doing VSS.No cross connection, mean
FW01 g0/1- SW01 g0/1,
FW02 g0/1- SW02 g0/1.
Question: Can i do L2 etherchannel on this case, the challenge i se reside at the FTD side.
If not support, mean the loop prevention still stick back to STP, am i correct?
Any comment welcome, thanks
Noel
balaji.bandi
this is not best approach here, with the single Link to parent switch, Suggest model always have dual link to both the switches in VSS / vPC deployment
you can find deployment models as below :
https://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/clustering/ftd-cluster-solution.html
BB
Hi Sir,
Thanks for the comment.
But due to single connection from each device this constraint, can i say the link between sw02 - passive ftd unit will have STP block mode, to prevent loop?
Noel
if that is contrain of the deployment, and we need to consider as Risk and deploy.
where is the STP coming in to picture here ?
BB
