Cisco Static Route
winfulmatts
Level 2
Level 2
Hello All,
One of my clients have multiple branches and all their resources are in the head office data center.
They have double router for VPN and Internet. for the Internet router, we are using a small dlink router, but now they want to change it to a Cisco router. All settings have been completed but the issue now is how to input the static route.
This is what is configured statically in the Dlink router,
Route Name   Destination Address   Sub Mask   Default Gw    Interface   Metric
Servers          192.168.110.0    255.255.255.0  192.168.4.254    LAN         15
Clients           192.168.120.0    255.255.255.0   192.168.4.254    LAN         15
How do i input this static route in the Cisco router?
mehulnangru
Try adding below on the router -
ip route 192.168.110.0 255.255.255.0 192.168.4.254
ip route 192.168.120.0 255.255.255.0 192.168.4.254
where sytax is as below :-
ip route X.X.X.X Z.Z.Z.Z Y.Y.Y.Y
X - LAN subnet
Y - Exit interface (which will be you internet router WAN address -192.168.4.254)
Z - Subnet Mask
For more details have look at below :-
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/27082-ip-static-routes.html
5 Replies 5
mehulnangru
X - LAN subnet
Z - Subnet Mask
Ganesh Hariharan
Hello Winfulmatts,
You would require three routes One is the deafult route towards internet and rest two would be LAN subnet routes towards your LAN switches.
ip route 0.0.0.0 0.0.0.0 ISP router ip address
ip route 192.168.110.0 255.255.255.0 192.168.4.254 -- LAN switch Vip or ip
ip route 192.168.120.0 255.255.255.0 192.168.4.254 -- LAN switch Vip or ip
Hope it Helps..
-GI
Rate Helpful Posts
This is helpful too, but in this case, both routers are connected to the same ISP but for different services, the default gateway 192.168.4.254 is actually the VPN router that is pointing to the HQ for all services like dhcp and the likes.
So the
ip route 0.0.0.0 0.0.0.0 isp router add
will be of no effect here.
thanks.
Agree with your point, but i was under impression that this router is for internet and would require a default route towards isp required for forwarding traffic.
But anyhow you glad you got your query clarified.
-GI
Thanks GI, i also taught as much.
That's what i actually did initially until i found out it wont work at the least.
Thanks anyways.
