Cisco SW, changing interface config missing commands
Hi there,
I have the following port on a Cisco Catalyst 2960, configured as follows below.
But will need some of the configurations to be changed in to the configuration I entered with in [...]
Can you recommend/advised what are the command to change those lines? I have changed the other settings already but could not get these ones going yet.
Thanks so much for your help!
[ADDING "DESCRIPTION" LINE : AccessPoint]
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: on
Access Mode VLAN: 100 (Management) [CHANGE TO VLAN 1 (DEFAULT)]
Trunking Native Mode VLAN: 1 (default) [CHANGE TO VLAN 100]
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
many many
these mainly for trunk and private.
so you need to check
trunk mode command
VTP command
private vlan command
Thanks @MHM Cisco World , did a mistake in pasting the info in the message. I found most of the commands, just the one marked now missing so far. Thanks again for your help!
You are so welcome friend
