cisco Switch 1000
avdhesh
how to disable the MODE button ? (disable the factory reset function) ,
Hi all,
I need to disable the "press MODE button more than 10seconds" factory-reset feature.
The button is way too close to port 1 and I have a real life example of someone erasing the switch config
how i can prevent switch  to factory - Reset
Thanks in advanced
@avdhesh use below command in global config mode.
#no setup express
Good luck
KB
This Command is not available on cisco 1000 #no setup express
>>> This Command is not available on cisco 1000 #no setup express <<<
-> this statemen is incorrect, see output below "setup express" is available, and also the "no setup express"
Switch Ports Model SW Version SW Image
* 1 10 C1000-8FP-2G-L 15.2(7)E7 C1000-UNIVERSALK9-M
switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)#setup express
switch(config)#no setup express
switch(config)#
@avdhesh use it in global config mode.
Good luck
KB
