Cisco Switch 2960X-48LPD Radius configuration
Antony.xavier
Hi There,
I recently upgraded Cisco Switch 2960X - 48 LPD from 15.2(7)E5 to 15.2(7)E5 after the upgrade I am not able to authenticate through Radius server.
Please note: Radius authentication was working fine in the pervious IOS version 15.2(7)E5.
Please guide me the CLI configuration steps to performed.
Antony Xavier
5 Replies 5
Jitendra Kumar
check below documents will guide you for the Radius config...
config command also available..
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/security/configuration_guide/b_sec_152ex_2960-x_cg/b_sec_152ex_2960-x_cg_chapter_010000.html
Jitendra
Jitendra
marce1000
        - What's in the logs of the radius server ?
 M.
Antony.xavier
Hello Everyone,
I was able to configure NPS radius  server, below is the configuration. FYI.
config t
radius server (name of the server)
address ipv4 1.1.1.1 auth-port 1612 acct-port 1613
key 0 XXXXXXXX
exit
config t
aaa group server radius (name of the radius server)
server name (name of the server)
exit
regards,
Antony
Congratulation you are a rock star..
Jitendra
Jitendra
radius-server host x.x.x.x auth-port 1612 key y.y.y.y
try this way
