Ruggedized Cisco Switch IE-3300-8U2X-E
Does Cisco Switch IE-3300-8U2X-E have Dual Stack IPv4/IPv6 feature ?
5 Replies 5
In data sheet, it is mentioned that the switch support IPv4 and IPv6, but it is not mentioned that it supports dual stack IPv4/IPv6 clearly in data sheet.
balaji.bandi
These are more Industrial switches - less hands on, as per the information, there is some limitation :
https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie3X00/software/17_3/b_ip_routing_17-3_iot_switch_cg/m-171x-ipv6-unirt-iotsw.html?bookSearch=true
BB
I need a clear answer whether this model Cisco Switch IE-3300-8U2X-E supports dual stack IPv4/IPv6  or does not support, please
 - Note that your question is posed towards  a volunteering-forum , if you need clear answer in business context , then you need to contact Cisco (TAC).
 M.
