Firewall tries to close a BGP/TCP connection with switch
FNL
  The following problem involves a firewall (10.249.0.13) wanting to close a BGP connection with its neighboring switch (10.249.0.14).
The switch answers with a BGP NOTIFICATION message that contains "No supported AFI/SAFI". (separate issue) The firewall then sends a FIN to the switch to close the TCP connection. Follows a series of FIN retransmissions from the firewall and ACK retransmissions from the switch.
Is there a way to determine which side is not understanding here?
I have included an excerpt of the .pcap.
are you config FW to bypass BGP or it BGP peer?
No we're not.
Thanks a lot for the link, I will check that out.
