Cisco switch 4948 ios not load
dinda_adwaita1
Hi  I have Cisco switch 4948 . It was rommn mode but after boot the switch from tftp server now it working. But IOS not load bootflash. As per configuration manual it's not ping from switch to tftp server. I also use straight cable from switch mgm port to pc nic.
My point is I can boot switch from tftp server but when copy IOS from tftp to switch that time it show error request time out.
Please any body help me.
Philip D'Ath
So it sounds like you have a lack of connectivity between your 4948 and your TFTP server once the switch has booted from TFTP.
Rather than using TFTP, have you got an HTTP server somewhere on the Internet you can put the image on, and load it from that?  Can you ping the Internet ok?
I would be tempted to format the flash first as well (in case it has some corruption), once the switch has booted into IOS (not from ROMMON):
format bootflash:
Then when the switch is running (not from rommon), something like:
copy http://x.x.x.x/cat4500-ipbasek9-mz.....bin bootflash:
