Cisco Switch 9500 Nexus snmp v2c
mrjelly
I am attempting to setup a Nexus 9500 with SNMP v2c. However the switch has auto added the local logins as SNMP users.
I therefore am getting incorrect user errors when attempted GET requested from my monitoring software.
Is there a reason it added users automatically, is there a way to allow for no authentication SNMP v2c using the community name?
thank you
ALL users can be used to authenticate for snmpv3, not only on Nexus, also on other models
including AAA users
Cisco Nexus 9000 Series NX-OS System Management Configuration Guide, Release 10.1(x) - Configuring SNMP [Cisco Nexus 9000 Series Switches] - Cisco
- The device supports SNMPv1, SNMPv2c, and SNMPv3. Both SNMPv1 and SNMPv2c use a community-based form of security.
If you create or delete a user using either SNMP or the CLI, the user is created or deleted for both SNMP and the CLI.
-> if you get an incorrect user error, it looks like your monitoring software is using snmpv3 instead of snmpv2
pieterh
AFAIK snmpv2c uses community name only
usernames are used by snmpv3!
=> your monitoring software has switched to snmpv3
or   your snmp-server command has been changed to
     snmp-server host <ip-addr> version 3 priv < username>
-> change back to snmp-server host <ip-addr> version 2c <community> (if IOS allows)
Yes that was my confusion, my command on the switch is still v2c and the monitoring (PRTG) is set to v2c.
I wondered if this was some sort of Nexus kwerk where it auto adds users that confuses things if you are using v2c.
Thank you
including AAA users
Thank you for your help on this, I have relooked and there was a setting part way down an inherited setting to make it SNMP v3.
SNMP v2c was at the top level.
