Basic Steps to creating a switch stack by adding second switch
BarestOfMargins
Frequent Visitor
Frequent Visitor
Hi all
Appreciate help here as I dont want to make any errors with this.
I have a switch in production, 1 x 9300, they have added new office nearby and patched back to same rack as this, I have another 9300 I can add but I dont want to run the risk of taking anything down as this isnt something ive done before.
If its the case downtime is avoidable, so be it, I will perform out of hours, but if someone could provide the basic steps to this that would be great. Most guides I can find are adding second, third switches to existing stacks, or creating from scratch, whereas I want to add 1 switch to a live switch with no stack config setup already....
Thanks very much
DYARIBARHAM
Community Member
Since you do not want to stack them, I suggest configuring the switch from scratch to avoid taking anything down.
Note: It is best to back up the configuration of the old switch just in case.
Hiya, thanks for your reply. Just to be clear, I DO want to stack them, but one has no config, and the other is a live switch in production. I want to add it as the second switch in the stack as easily and as hassle free as possible basically
As long as the existing switch is correctly numbered as first chassis you should simply be able to pre-provision the second switch then add it to the stack.  Before adding the new switch make sure it is numbered as the second chassis.  You should still plan to make the change "out of work hours" just in case you have any unexpected reloads.  Also best to make sure that you have exact same IOS installed on the 2nd switch before adding it, also in the same mode (install or bundle mode).
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
balaji.bandi
basic checks - make sure both models should be same, they have same IOS XE code and Licese.
1. make sure you offload the config out of the box safe (from the active live device)
2. Offline build the new switch  with Correct IOS XE to match with exiting Stack
3. change the Switch numnber and priority.
4. save the config and turn off the device.
5. Prepare the racking and mounting the kit in
6. configure on the Live stack switch provisioning.
7. connect the Stack cable (hope below URL give the information)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
8. Power on the new Switch you looking to be part of stack.
Monitor  the Logs - show switch give you information
BB
