Cisco switch and Router and cabling
zillah2004
As we know , if we want to connect PC to cisco switch we are going to use straight through cable, and between PC and router we are going to use cross over.
Now can adopt that when we have similar devices ( PC and router (mini PC)) ,we use cross over ?
and when we have different devices (PC and switch) we use straight through?
Dose this adoption work for any other router's brand and switch , or it is only for cisco?
thisisshanky
Level 11
Level 11
That feature is called as Auto MDIX. It is available in many other vendor switches like HP. I doubt if Mdix is supported in Cisco routers though. (Not sure if PC nics do support the same)
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
My understanding(correct me if I am wrong) to what you said that: MDIX (the “X” representing “crossover”),is an Ethernet port that allows using crossover cable.
Now with cisco router you doubted if this feature is available,,,I am right? Then how can the cisco router be connected to another cisco router ? normaly we use crossover.
MDIX is available on the 3750.
IOS (tm) C3750 Software (C3750-I5-M), Version 12.1(19)EA1c, RELEASE SOFTWARE (fc
2)
interface FastEthernet1/0/15
description DESKTOP-LAB
switchport access vlan 224
no ip address
mdix auto
end
