02-21-2023 02:21 AM
Do Cisco have one?
The Cisco switches I have inherited are several firmware version behind so I wanted to check if I need to follow a path or if I can jump to the latest version?
SG350-28 28-Port Gigabit Managed Switch running firmware version 2.4.0.91. The latest firmware version is 2.5.9.15
Cheers
Josh
Solved! Go to Solution.
02-21-2023 03:51 AM
- For SG350-28 , you can jump to latest available firmware directly ,
M.
02-21-2023 03:51 AM
M.
02-21-2023 05:41 AM
i would also suggest to read the release noted before upgrade and understand some caveats may effect you,
