EEM script for changing VLAN configuration as per port description
bibekananda
I am looking for an EEM script, when  VLAN number is included in the switch interface description, switch port VLAN configuration will be changed accordingly.
Suppose I configured "Connected to PC VLAN 12" on description field of interface G1/0/1 then switch port will be automatically configured as
switchport mode access
switchport access vlan 12
spanning tree portfast
M02@rt37
Hello @bibekananda
Assume that the interface description field contains the string "PC VLAN" followed by the VLAN number. If your description field has a different format, you may need to modify the regular expression in action 3.0 to match your format:
event manager applet configure-vlan
event syslog pattern "Interface.* changed state to up"
action 1.0 cli command "enable"
action 2.0 cli command "show interfaces description | include PC VLAN"
action 3.0 regexp "Interface (.*) .*PC VLAN ([0-9]+)" "$_cli_result" match intf vlan
action 4.0 if $_regexp_result == 1
action 5.0 cli command "configure terminal"
action 6.0 cli command "interface $intf"
action 7.0 cli command "switchport mode access"
action 8.0 cli command "switchport access vlan $vlan"
action 9.0 cli command "spanning-tree portfast"
action 10.0 cli command "end"
In this script, the event manager applet is triggered whenever an interface changes state to up. It searches for the string "PC VLAN" in the interface description using the command "show interfaces description | include PC VLAN".
It then uses a regular expression to extract the interface name and VLAN number from the description field. If the regular expression matches, the script configures the interface with the necessary settings for access mode, VLAN assignment, and portfast.
Also, you should find othet information if you follow this Cisco Documentation.
Best regards
Thanks for your response. but unfortunately its not working. After applying this script getting follwoing log message
%HA_EM-6-FMPD_EEM_CONFIG: configure-vlan: Missing "end" action in conditional block.
I am not really sure what is supposed to trigger this event. I have adapted the script posted by M02@rt37 and used 'event none', which means you have to run it manually.
event manager applet INTF_DESC_VLAN
event none
action 2.2 foreach line "$_cli_result" "\n"
action 3.0 regexp "(Gi[0-9/]+).*PC VLAN ([0-9]+)" "$line" match intf vlan
action 4.0 if $_regexp_result eq "1"
action 9.1 end
action 9.2 end
Please @bibekananda
Add this at the end of the script:
action 11.0 end if
action 12.0 cli command "end"
Also I modified a little bit action 3.0
Please find this script:
action 3.0 regexp "Interface (.*) .*VLAN ([0-9]+)" "$_cli_result" match intf vlan
action 11.0 end if
I let you try also what @Georg Pauwen tell you about the command:
Best regards
