Cisco switch how to connect with CSSM
kick534
Hi Team,
Please i need help to register my Cisco switches 9000 series.
already i read documents regarding this, but i cannot understand how to connect switch with internet,
Cisco series Switches 9400 are in VSS mode configured but not in production , please guide me how shuld i connect internet to switch
balaji.bandi
Do you have CSSM on site :
https://www.cisco.com/c/en/us/products/collateral/software/smart-accounts/white-paper-c11-741659.html
You do not satellite Smart License Server then you need to connect your device to Smart License server to register License :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/configuration_guide/sys_mgmt/b_169_sys_mgmt_9300_cg/configuring_smart_licensing.html
Process is - you need to use OOB or Manangement VLAN for the device to reach Internet using https to register ( i generally prefer using any Proxy so they are secure behind proxy or FW to protect against external access).
BB
balaji.bandi
BB
hello,
Still i confused in connecting with internet( I have two switches 9400 series i just configured VSS in it now i want to register the licenses )
how can i connect this switchs and provide internet ( the switch not in production)
Please provide steps.
After registration we need to save the configuration ???
Actually when i follow all the steps the switch Registered every thing looks fine , But i did not save the configuration.
and physically power of the switch, now once again i try to power on the switches its shows again eval mode please help.
 if the devices registered we need to save config ???
balaji.bandi
Saving config not going to harm, since you changed the config, so always suggest to save the config and reload and test it.
BB
